Non-Power Power Brakes - NCRS Discussion Boards
  • Marlin F.
    • November 29, 2010
    • 27
    I'm back! Thanks for the help in solving the binding accelerator linkage problem.
    New issue: my 327/350 4-speed apparently has power brakes, but they aren't working properly. When the pedal is depressed, I can hear what seems to be a vacuum hose trying to 'suck' something. The sound seems to come from just behind the dash. A cursory look under the hood doesn't show anything out of the ordinary and the noise from the engine prevents me from hearing the sound.
    Any ideas?
    Thanks!
    Re: Non-Power Power Brakes
    Any ideas?
    Thanks!
    Marlin -
    That's normal - it's air rushing in through the power valve to occupy the void behind the main diaphragm; there should be a circular foam filter there to minimize the noise, which has probably crumbled to dust.
