67 Hartop- What's this sealer - NCRS Discussion Boards
  • Gerard F.
    • June 30, 2004
    • 3806
    Looking for an uptodate sealer, to replace this original stuff:
    This is the mastic sealer which goes between trim and the frame of the hardtop above and in back of the side window and to the rear window. It is kind of a black mastic, still a little soft after all these years. You can see the part number of the trim embedded in it.
    The Dow Smith Assembly manual (thanks Harry) for the hardtop refers to it as Sealer 3840733. The 67 Chassis Service Manual refers to it as a "polyurethane sealer obtained through Chevrolet Parts sources" but the picture showing it being applied shows it as white.
    Anyone know of a current day substitute for this stuff?
    Jerry Fuccillo
  • Douglas L.
    • August 31, 2003
    • 302
    Re: 67 Hartop- What's this sealer
    Jerry,
    I used black 3M Strip Caulk
    • Dennis C.
      • June 30, 2002
      • 888
      Jerry,
      3M makes a non-hardingbedding compound that might work. I believe the number is 8509.
      Dennis
