67 Ribbed Heater Hose - NCRS Discussion Boards
  • Kirk M.
    • June 30, 2006
    • 1036
    I have been told by two judges now that this hose should NOT be ribbed. Where can I purchase a GM stamped, non-ribbed hose? Thanks.
    Kirk
  • Mike M.
    • May 31, 1974
    • 8391
    Re: 67 Ribbed Heater Hose
    buy a 25' box of black 5/8 and 3/4" non-ribbed smooth black rubber heater hose from local auto parts store(you may have to do some traveling about to find a source locally). get the local rubber stamp maker to make some stamps(use the repo hoses you have for template for rubber stamp maker. buy a 15cc bottle of white and red ink from Quanta (they ad in driveline) and have at it. good luck,mike
    • David S.
      • August 9, 2009
      • 595
      Kirk,
      I also believe Bill Calorico, the 66 Team Leader, has the correct hoses, if you did not want to create them yourself.
      Best,
      Dave
      • Brian M.
        • February 1, 1997
        • 1839
        I would think that Dr. Rebuild would have them, he has the best rubber products. JMHO
          Kirk
          Kirk -
          Paragon has a 5/8" non-ribbed hose with the GM logo - their #2000; just cut off the molded end and cut the length to suit your needs.
          • Kirk M.
            • June 30, 2006
            • 1036
            Kirk -
            John,
            I'm not coming up with hose with that part number. Could it be something else?
            Kirk
            • Brian M.
              • February 1, 1997
              • 1839
              Did you try Dr. Rebuild?
              John,
              Kirk
                John,
                Kirk
                Kirk -
                It's in their current C3 catalog on page 79.
                • Kirk M.
                  • June 30, 2006
                  • 1036
                  Thanks. Was looking in C2 catalogue.
                  Kirk
