How many 1990 corvettes were build like mine? - NCRS Discussion Boards
  • Jaap D.
    • April 6, 2010
    • 13
    Hello,
    Can anyone help me to find out how many c4 were build in 1990 with the same options as mine?
    I have a buildsheet, black book but i can`t find it out.
    The corvette is one of the 951 european exportmodels. It was shipped to the U.K.
    Jaap
  • Eric J.
    • March 1, 1980
    • 771
    Re: How many 1990 corvettes were build like mine?
    Jaap, Plug your vin in here and it will tell you:
    Eric
    • Tom H.
      • December 1, 1993
      • 3440
      I have also tried this site and found it to be well........................ Not so accurate.
      Tom Hendricks
      Proud Member NCRS #23758
      NCM Founding Member # 1143
      • Eric J.
        • March 1, 1980
        • 771
        Yes it compares all sorts of RPO codes that tend to make the car more unique, but if you only check the RPO codes that you are interested in it will count the number made. the ZR-1 Registry guys used this data to get color counts and found that the data is fairly accurate as long as you remove the noise.
        • Jaap D.
          • April 6, 2010
          • 13
          Thanks Eric,
          That`s what i was looking for! Great help, i`m very pleased with it.
          The car is not unique, but this is what came out:
          There are 1 1990 CORVETTE 2 DR vehicles (0.006%) matching your exact options list. There are 1 (0.006%) with at least as many options.
          I,ve tracked the history down to it`s second owner. Still trying to get in contact with the first owner.
          Greetings
          Jaap
          • Michael W.
            • April 1, 1997
            • 4290
            Jaap,
            Unless I misunderstood, this site just multiplies one percentage by another to get a derivative. The more RPOs plugged in, the closer it will end up by giving a one-of-one answer. Just about any Corvette will appear to be 'unique' when playing similar number games.
            Want a real 'rare' Corvette? Try to find one with NO options at all. According to the stats calculators there should be tens of thousands of them..........
