67 Glove Box Light Shield and Striker - NCRS Discussion Boards
+ More Options
Posts
  • Kirk M.
    • June 30, 2006
    • 1036
    Can someone show a picture of the "O" on the light shield and the "P" on the striker of the 67 glove box light assembly? Thanks.
    Kirk
  • Scott S.
    • September 11, 2009
    • 1961
    Re: 67 Glove Box Light Shield and Striker
    Kirk
    Hi Kirk,
    Is this the "O" you are looking for? Not easy to blow the picture up large enough to see it clearly without losing detail.
    • Steve B.
      • February 28, 2002
      • 1188
      Scott, that is the same as mine. The striker plate on mine has a P stamped on it.
      • Kirk M.
        • June 30, 2006
        • 1036
        Steve,
        Could you take a picture of the striker plate? Thanks.
        Kirk
        • Steve B.
          • February 28, 2002
          • 1188
          Kirk, I just tried but it always comes out blurry. I will try again and if it comes out clear, I will post it.
          • Scott S.
            • 1961
            I think I was able to get a decent picture of the "P".
            UPC 1ASM, Sheet E4, Item 14, "3841222 Striker". Mine had two chrome Philips washer-head screws (Item 18, "3756994 Screw") with two washers for each screw (washers not shown in the AIM).
            • Kirk M.
              • June 30, 2006
              • 1036
              Thanks. Appreciate it.
              Kirk
              • Steve B.
                • February 28, 2002
                • 1188
                Scott, thanks for the pic. My car just uses the screws with no additional washers.
                • Scott S.
                  • 1961
                  Hi Steve,
                  The glove box liner is torn in that area, which might have required additional washers as spacers. If it doesn't need the extra washers, I won't use them. I was able to find an NOS glove box liner, but the original is otherwise in great shape, I would rather re-use the original if it can be repaired.
                  Is there a way to effectively repair damage like this?
                  • Steve B.
                    • February 28, 2002
                    • 1188
                    Scott, I'm not sure if that can be repaired or not. Hopefully someone will provide a better answer.
