If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
On my 1966 backup switch connector behind the ballast resistor. What is the "release" process of this connector from the harness??? I have tugged and probed, but am afraid I will hurt 40+ year old harness, thus this question.
Larry
Larry -
There's no locking feature on that connector; just work the two pieces back and forth and pull them apart (pulling on the plastic connector bodies, not on the wires).
