I've recently restored a 63 and a 65 rear spring and have learned a couple of things I thought I would share. Most may know the 63 rear spring is a single stage design and all 9 leaves are arched, but did you know the arch is not quite as pronounced on the 63 design? While I had these apart, I measured the arch of each of the first 6 leafs and got these results.
............63 spring........65 spring
leaf 1......8 5/8".............9 3/4"
leaf 2......7 3/4".............8 3/8"
leaf 3......6 3/8".............7 1/8"
leaf 4......4 7/8".............5 3/4"
leaf 5......3 3/4".............4 5/8"
leaf 6......3 0/0".............3 3/8"
The arch was measured on the bench with both ends butted to a straight edge. The distance measurement is from the straight edge to the inside surface of the center of the spring.
This pic shows a leaf by leaf comparison. the spring on the top is the 65 spring leaf in all cases. These are both low mileage takeoffs, so I'm confident the 63 is not just worn out. This may be common knowledge to some, but I learned something.
I also found some pretty compelling evidence that both sides of the 65 spring leaves were painted. This pic shows the compression (upper) side. I've always read that only the tension (lower) side of the leaf was painted.
