If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Hi, need to now wich is the cranckpulley for 1959 283 fi engine. also if is possible to installed a fi unit in a regular 283engine with hydraulic lifters?
Edwin-
The crank pulley info should be in your '58-'60 Judging Guide.
F.I. was available in '59 with hydraulic lifters (250hp, "CR" and "DH" suffixes).
