I notice an old US Royal tire I have (no DOT) shows no recommended maximum pressure on the sidewall. The '65 owner's manual says cold pressures are 22 psi (front) and 24 psi (rear).
I have some repop Firestones (goldline & whitewall) [New Zealand and USA manf., respectively], both DOT numbered, with 32 psi max indicated.
What cold pressures would you recommend ?
