I need to know the correct voltage regulator for a car that has both C-60 & K-66. I have had multi-cars with TI and they all had a #1119515 regulator, just like all standard ignition cars I have seen-located on the inner fender next to the alternator.
Now, I am building an A/C car and it also has TI. In looking in the 66 judging manual, it does not mention any difference in standard or TI, or A/C. However, in judging I have seen used (with C-60 & K-66) a #1116368-the cool looking transistorized piece. The owner said it was correct with combo of C-60 & TI-I yielded to the owner, as I did not have facts to the contrary.
I checked the 66 AIM: under standard equip, UPC 6, ref B4 it calls for #1119515, just like I would expect.
Then I checked under UPC K-66, ref A2, and it just confused me, it has:
1116368 Voltage Regulator Asm.
1119515 C-60
It is printed on two lines, just as I have written. So, does this mean the notel of Voltage Regulator Asm. & C-60 all refers to the #1116368, or does it mean the C-60 refers to the #1119515 only, which is contrary to everything I have seen?
The other thing strange I found on the A2 page is the location it calls for as to where to mount the regulator: not next to the alternator, but rather on the rear of the inner fender, where on an A/C car, is where the battery, removal panel and windshield wash bag are. If I read Noland Adams book correctly in the K-66 section, it calls for #1116368 as standard and the #1119515 with TI-he does not cover the combination of C-60 & K-66-I think he noted the two lines in the AIM and was confused also and it did not get edited.
So, does anyone have a car with A/C & TI (or reference material or factual knowledge of) to verify the correct regulator called for with this combination and where it should be mounted.
Mike Zamora
#12455
1119515 C-60
Mike Zamora
#12455
). I also have a 4K and a 6A. Could never figure out the latter, as I was always under the impression that the 1116368 became the 1116378 in 1967 and they added a 'B' suffix sometime after that. There's a TSB on the problems with the '368' which was corrected by adding a diode to prevent surges/failure when engine was shut off while heavy demand electrical components were operating.
) that the original '368' lasted about 1 year, then was replaced.
