My 55 manifold is really different than any I have seen. Please see Pics. It has a date of E / 99 That's it. The heat shield inside is larger than a regular 55 and the porting is very well done? GM kept the car until Sept. of 55 where it was sold as used? I'm not sure what they did with it from Jan to Sept?
55 Intake Manifold Questions
Re: 55 Intake Manifold Questions
Your's say E199 =May 19 9?= 90's?
But I have you beat here is one I have having NO dates, so I could use it on any dated engineAttached FilesLast edited by Roy B.; June 17, 2010, 07:31 PM.- Top
By the way what number 55 you have- Top
Here is a little trivia about those screw marks at each end of the date.Attached Files- Top
I think you'll find the following coding to be correct for the date tag screws and the "casting clock" (the double-dots at 12 o'clock indicate the start of the shift). Info came from fellow NCRS member Mark Gorney at the Saginaw Foundry (now called Saginaw Metal Casting Operations); Mark has been there for over 30 years, and provided me with key research for my 2002 '67 intake manifold survey article in the "Restorer".
The date tag screws indicated the shift when the casting was poured:
- Top
