66 coupe windshield corner moulding - NCRS Discussion Boards
  • William P.
    • August 31, 2003
    • 135
    The top passenger outside corner moulding on my 66 does not fit well. Is there an easy way to remove and re-set this trim.
    Regards Bill Purdy
  • Stephen L.
    • May 31, 1984
    • 3162
    Re: 66 coupe windshield corner moulding
    Not easy. The clip that attaches the chrome was installed before the windshield. If this is loose you'll need to remove the glass. If you remove the moulding you run the chance of damaging the clip. If the moulding is loose you might try using windshield sealer to hold the moulding in place
    • Russ S.
      • April 30, 1982
      • 2163
      Carefully pull the moulding up and off and then bend the mounting tangs to reposition the moulding so that it lines up with the other moulding.
