C1 fan spacer - NCRS Discussion Boards
C1 fan spacer
  • Jim K.
    • March 1, 1978
    • 49
    C1 fan spacer
    Hi to all ; Can anyone tell me if a fan spacer (mounts between the water pump pully face and fan) was ever used on the 56 265 engines to help with cooling. I have a 3" spacer that I am considering using. Also what is the correct degree themostat to put in the 56 265 . Thanks for the help, Jim
  • Roy B.
    • February 1, 1975
    • 7044
    Re: C1 fan spacer
    Originally posted by Jim Kish (1845)
    Hi to all ; Can anyone tell me if a fan spacer (mounts between the water pump pully face and fan) was ever used on the 56 265 engines to help with cooling.NO I have a 3" spacer that I am considering using. Also what is the correct degree themostat to put in the 56 265 . Thanks for the help, Jim
    "160" some I've seen use 170 or 180 no higher
    • Mike M.
      • May 31, 1974
      • 8408
      Re: C1 fan spacer
      no spacers were used.mike
      • Robert L.
        • April 30, 1979
        • 97
        Re: C1 fan spacer
        If I recall, a spacer is used. It is the same thickness as the motor mount bracket. This lines up the belt to the generator and water pump.
        MCMLVII
        • Mike M.
          • May 31, 1974
          • 8408
          Re: C1 fan spacer
          MCMLVII
          Bob: i believe you are thinking of the spacer that inserts on the crankshaft nose before installing the harmonic balancer. mike
          • Robert L.
            • April 30, 1979
            • 97
            Re: C1 fan spacer
            Thanks Mike,
            It has been awhile, I knew there was one in there somewhere.
            Bob
            • Jim K.
              • March 1, 1978
              • 49
              Re: C1 fan spacer
              Roy, Mike, Bob; Thanks for your help answering my questions. I will put in the 60 degree themostat and foget about the 3" fan spacer. Best regards, Jim
