'60 engine pad
  • Frank B.
    Infrequent User
    • January 1, 2000
    • 9
    '60 engine pad
    What does the engine pad look like for a 1960, single carb, powerglide and serial number 01766 look like? Sorry if this has been discussed multiple times in the past, but I checked the archive back to '08 and could not locate a complete answer.
    Frank
  • Jim D.
    • July 1, 1985
    • 2882
    Re: '60 engine pad
    On the left side of the pad, it would be stamped 101766. These would have been done one at a time without a gang holder and sometimes they don't line up very well. The other stamp was with a gang holder. It will start with an "F", then the assembly date, then a "DG" suffix. This is one 65 cars before yours.
    • Ray C.
      • July 1, 2001
      • 1132
      Re: '60 engine pad
      Frank, your 1960 VIN number-101766 is a December 16, 1959 built car. I would try and find some 1960 cars that were built just prior and after yours to see if the VIN number was stamped into the engine pad. It is my understanding that the VIN number was added to the 1960 pad on or about mid December of 1959 (1960 model year).
      Ray
      Ray Carney
      1961 Sateen Silver 270-HP
      1961 Fawn Beige 315-HP
      • Donald H.
        • November 2, 2009
        • 2562
        Re: '60 engine pad
        My 1960 101322 is stamped on the pad. I've only had the car for 6 months and am into a frame off restoration, so I don't have any history with the car and don't know if the stamping is original factory or someone later.
        Don Harris
        Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
        • Ray C.
          • July 1, 2001
          • 1132
          Re: '60 engine pad
          Hi! Donald
          That would make yours a mid November 1959 built car. Does the VIN number look like the charters were individualy stamped or gang stamp?
          Ray
          Ray Carney
          • Jim D.
            • July 1, 1985
            • 2882
            Re: '60 engine pad
            Don
            Could you e-mail me a picture of your stamp pad. I've been researching/collecting info. and pics. on 1960 pads for 30 years. The earliest I have that is hand stamped is #1617.
            Thanks,Jim
            • Jim D.
              • July 1, 1985
              • 2882
              Re: '60 engine pad
              Ray,
              The belief that it started in mid-Dec. is incorrect.
              Jim
              • Ray C.
                • July 1, 2001
                • 1132
                Re: '60 engine pad
                Hi! Jim
                What was the date for the first pad to receive the VIN stamp?
                Ray
                Ray Carney
                • Jim D.
                  • July 1, 1985
                  • 2882
                  Re: '60 engine pad
                  Originally posted by Ray Carney (36314)
                  Hi! Jim
                  What was the first pad to receive the VIN stamp?
                  Ray
                  I've narrowed it down to somewhere between #1136 and #1617. A picture of Don's would allow me to narrow that down considerably.
                  Jim
                  • Donald H.
                    • November 2, 2009
                    • 2562
                    Re: '60 engine pad
                    Here's a picture, not very good. Car serial number is 101322. Anyone got know how to make the stamping stand out more?
                    As I said, I have no idea whether this is original or some past re-stamping.
                    Don Harris
                    • Jim D.
                      • July 1, 1985
                      • 2882
                      Re: '60 engine pad
                      Don, Could you e-mail me that pic. as a JPeg file so I can clean it up in Photoshop? It is slightly out of the norm of what I've documented so far that the assembly date of the block is only 2 days before the car but anything is possible. What is the casting date of the block? From that picture, it looks original to me. I'll know more if I can examine the picture closer. Thanks for posting.
                      Jim
                      • Donald H.
                        • November 2, 2009
                        • 2562
                        Re: '60 engine pad
                        Jim,
                        Casting date is J 1 9, which I assume is September 1, 1959. I am sending you a couple of different pictures, original JPEGs.
                        Don Harris
                        • Frank B.
                          Infrequent User
                          • January 1, 2000
                          • 9
                          Re: '60 engine pad
                          Jim,
                          If I understand what you are telling me my pad would have 101766 on the left and FI2??CQ right side, where the question marks would be number(s) ranging from 02 to something like I0 or II, assuming that the car is December 16 car? And am I correct in reading the pad in the photo that the engine build date is Dec 02, '59?
                          Frank
                          • Jim D.
                            • July 1, 1985
                            • 2882
                            Re: '60 engine pad
                            Frank,
                            Yours should have a "DG" suffix not the "CQ". Yes, the assembly date in the pic. I posted is 12-02-59
                            Jim
                            • Keith R.
                              • September 1, 2001
                              • 660
                              Re: '60 engine pad
                              Originally posted by Jim Durham (8797)
                              Don
                              Thanks,Jim
                              Jim,
                              I am getting ready to stamp my new block on my 103062 VIN# (1/28/60 birthdate) and the JG says that around mid January 1960 they changed the stamp for the month of January from "I" to "0I". Presuming that the engine assembly date was seven to 10 days earlier than the vehicle assembly, I'm guessing that my month date stamp should be "0I" correct? Do you have any more information that pins down this transition date more exactly? Thanks.
                              Keith MacRae
                              NCRS #36692
                              New Mexico Chapter
                              1960 290HP FI
                              2013 427 Convertible
                              Shade tree mechanic and
                              B-52 pilot extraordinaire
