judging clutch pedal question 63-67
  • Jim R.
    • July 1, 2001
    • 643
    do they take points away if you have your clutch pedal in the short throw position as they do for the 4speed short throw.
    JR
  • Bill W.
    • November 1, 1977
    • 402
    Re: judging clutch pedal question 63-67
    Jim,
    Short throw on clutch or shifter is no problem UNLESS you are attempting a PV. Bill
    • Jim R.
      • July 1, 2001
      • 643
      Thanks Bill.
      JR
      • Wayne M.
        • March 1, 1980
        • 6414
        Originally posted by Bill Wilhelm (1600)
        Jim,
        Bill -- I realize that the '65 judging guide does not specifically mention high or low pedal adjustment, but to be consistent with the paragraph below, IMHO, there should be a flight deduct for non-TFP. Same for the shifter rods being inserted in the lower holes on the trans sidecover [1-2, 3-4] levers for a short throw (ie. not TFP). If the judge can read the maincase and sidecover casting numbers, he/she can see where the rods insert.
        The above items should be treated the same as for the quick steering. '65 TIM&JG says "Steering Knuckle .... non-PS cars use hole furthest from the spindle on the tie-rod ends". So there is (should be) a deduct [or at least a mention] of TFP for those manual steering cars with the N40-quick steer hole being used.
