If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
This tire is a goodyear wide tread 2 ply nylon cord. It is mounted on a jan 69' AZ wheel. Can anyone decifer the date code for me? If in fact this is the date code.
Thanks for all the help.
I can make out the last five numbers, but not the first two. Can you help those of us with poor eyesight?
