Aluminum Valve covers and Manifold Cleaning
  • Robert K.
    • November 17, 2009
    • 64
    Has anyone found a cleaner that takes the oxidation gas and oil off the aluminum valve covers and manifold? And makes them look clean and sum-what nice....???
    • June 1, 1974
    • 8332
    Re: Aluminum Valve covers and Manifold Cleaning
    until john degregory came along with a method to renew aluminum, i used Metal-prep, a phosphoric acid product available at any auto parts store. good luck,mike
    • Robert K.
      • November 17, 2009
      • 64
      Who's john degregory tell me more is his method out on the streets?
        • June 1, 1974
        • 8332
        john is one of the renouned FI restorers.he's from greensburg, pa. he also does aluminum. his method is a trade secret. you can send him yours for the re-skinning process. he ads in the driveline. good luck,mike
        • Joel F.
          • May 1, 2004
          • 659
          Mike,
          JD does valve covers but does not do carb intakes, only FI. That is what he told me so I sent my intake to Jerry MacNeish.
          • Dave B.
            • May 1, 1984
            • 248
            Try Albany Brake Parts Cleaner on a rag. It usually will do the trick.
