Thought I'd put this out. Need some advice before I screw this up. Was correctly orientating the distributor and installing new plug wires on my 59 and went to start it up, didn't start (thank god) on the first try, went to turn the key to "start" and key won't move, switch is stuck in "run". Will not go to "start" or "off". I can take the key out and put it in but can't turn it. Disconnected battery. Squirted some PB blaster in the key hole and around the key lock mechanism, no luck. Tried two other keys, one of which is an "original" almost never used. No luck.
This is the same ignition switch that's been in the car from at least 1974. Also, the lock appears to be a replacement since it has two holes for the paper clip and not one.
I searched the archives and the answers to those problems deal with turning the key CCW and using a paper clip to remove the cylinder. My key won't move. I did find a thread that stated you can drill it out using a 1/8 inch drill bit. Is that what I have to do now?
