If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
I am trying to run an antenna cable in my '56. The way I see it, I will have to remove the gas tank to route the cable in the original location. Is there an easier way than removing the tank?
