RE: 1957 fuel and temperature guage - NCRS Discussion Boards
  • Jerry B.
    • August 31, 1994
    • 416
    Good Evening I Have A 1957 Corvette And Decided To Have The Gauges Restored. When I Took The Car For A Ride For The First Time. The Temp. And Fuel Gauges Fogged Up. I Called The Rebuider And He Said That This Is Typical Because There Are Heating Elements Which Cause Them To Fog Up Due To The Rapid Change In Temperature. That Is Hard For Me To Believe. Your Comments! Thanks
  • Roy B.
    • February 1, 1975
    • 7044
    Re: 1957 fuel and temperature guage
    They can fog up any time, using a stronger bulb will help
    • Jerry B.
      • August 31, 1994
      • 416
      Roy, Thanks For Your Input. The Problem Also Occurs During Daylite Hours When I Pull The Car Out Of The Gargage. There Is Only A 15 Or So Degree Diffreence. Did This Problem Occur When This Cars Were New?
      • Pierre J.
        • July 31, 2000
        • 193
        I have the same problem with my '56 and '57.
        Pierre (34410)
        • Jerry B.
          • August 31, 1994
          • 416
          Hello Was Your Restorer Located In Flordia?
          • Roy B.
            • February 1, 1975
            • 7044
            It's the gages being cold and ether the dash lights or weather is warmer which causes the gages (metal) to warm up and creates condensation . Remember the air inside is trapped having no VENTED hole air . It's just a normal thing when the trapped air is not the same temp as the outside air. If there was a vent hole in the housing it would stop, that's why cars where the gages are open to the air don't do that that are not closed
            Yes even when new they had the same problem!
            • Tom P.
              • April 1, 1980
              • 1826
              Yep, under the right conditions, they will sometimes fog up to varying degrees in the 56.
                Yes. Both of my 57's did exactly the same thing - it's normal.
                P.S. Are you using some special software that capitalizes the first letter of every word, or??
