I need some help with an antenna mounting problem on my 1967 convertible.
This winter I dropped the gas tank and rebuilt the trailing arms, etc. While I was under the rear of the car, I removed the antenna and the antenna mounting aluminum shield since the old one was pretty beat up. Ordered a new aluminum shield from Paragon.
Trying to install today, and I cannot get the chrome antenna nut to thread onto the antenna body piece. The body piece does not protrude far enough out past the body for the nut to grab the threads. This was marginal with the old antenna aluminum shield. It also didn't fit well and had only 1-2 threads on the nut holding everything together.
What I need to find out is if the chrome antenna spacer and the threaded antenna body piece are correct 1967 pieces, or if Bubba substituted a few things years ago.
My chrome antenna spacer is about 1/4 inch high at its lowest point and 1/2 inch high at the tallest point. The rubber insulator adds about 1/16 inch to these numbers. I think this is correct.
My cast and threaded antenna body piece is 2-3/4 inch overall length. The black vinyl covered top section is 3/4 inch long, and the threaded section below this is also about 3/4 inch. The length from the centerline of the two small mounting posts/ears to the top ot the black vinyl section is exactly 2 inchs. I am not sure about this piece.
Would appreciate any help before I take the Dremmel to the new aluminum mounting shield.
![Big Grin](https://www.forums.ncrs.org/core/images/smilies/biggrin.png)
