Mid Year hardtop latches, same as soft top?
  • Larry T.
    • May 16, 2007
    • 404
    Are they the same? If not what are the different part numbers?
    Thanks.
    Director Region V
    • September 1, 1994
    • 1463
    Re: Mid Year hardtop latches, same as soft top?
    Yes, the same latches were used for both Hardtops and Soft tops.
    HaND
    • Larry T.
      • May 16, 2007
      • 404
      HaND
      Great, thanks.
      Larry
        • June 1, 1974
        • 8331
        Thanks.
        perhaps you are confusing the c-1 hardtops/soft tops. in that instance, the latches are different. mike
        • Larry T.
          • May 16, 2007
          • 404
          Just so I am clear, the 1963-1967 hardtops do use the same latches as the soft tops, correct?
          • Patrick T.
            • October 1, 1999
            • 1286
            Yes, the same latches were used for both Hardtops and Soft tops.HaND
            That's good for me, I bought a new set of latches for my '67 to complete the restoration. I still have the old ones in fair condition, so I'll polish them up and put them on my new acquired hardtop. The original latches on the hardtop are shot. PT
              • June 1, 1974
              • 8331
              yes........................ mike
                • 43129
                Thanks.
                Larry------
                GM #3825177, LH, and 3825178, RH. Same for all 63-67 for either soft top or hard top. Both are GM-discontinued.
                • Jack H.
                  • April 1, 1990
                  • 9906
                  On issues like this, cracking open your copy of the AIM (Assembly Instruction Manual) will often resolve things for you. You should be able to find the factory original PN's for the latches in the main section where the soft top is called out for assy. Then, flip to the option section for the hard top and see what PN's are defined...
