If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
GM dealers sometimes removed the knockout for owners and then gave both the separated keys and the knockouts to the owners, so either intact or separate is acceptable w/o a deduct, so long as the both components are presented to the judge.
