Trying to get a 67 roadster running for the first time since 1979. (It's a very rare one--it's a small block, and not 435 hp). (Original HH motor--California smog, 300 hp). In dropping the distributor in, I had a bit of an issue with aligning the rotor--the whole of of the distributor turned, even when it wasn't supposed to. (The football-shaped piece at the top of the shaft is loose on the shaft--and even I know that it's not supposed to be.)
As I think about brazing that back to the top of the shaft, I'm assuming that it's position on the shaft is critical to the timing. It's almost impossible to tell how it was related to the shaft from looking at it--any suggestions?
Thanks!
Thanks!
