If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
What is the purpose of the double wall for the steel pick-up tubes for the cabinet bead plasters? Also, why do they have the two crimps along the length that almost shut off the ID of these tubes.
Why even have these steel tubes. Won't the rubber hose stick in the media be good enough?
Steve L
73 coupe since new
Capital Corvette Club
Ottawa, Canada
I think its got to have some air flow to the end of the tube, not a lot, but enough to allow the media to flow like a liquid. As a grain of sand or media is picked up, something has to replace it and sand by itself is a solid and doesn't flow freely. Has to have air.
I'll have to look at mine closer...it has a steel pickup tube, but I was unaware that it was double walled.
From time to time, however, I have to use an old trick taught me by machinists at the refinery. When it's humid and the media flow stops or is significantly curtailed, hold the nozzle tightly against your gloved hand and give the air a burst. The air flowing back through the pickup tube fluffs the media allowing it to flow again. I believe that trick is probably a turbo version of the double walled tube.
the center tube is suction and the outer tube allows in air into to move the media. if you push the tubes till the top of the outer one is under the media there will be no pickup. JMHO
I didn't realize that the hose end of the tube needed to stay out of the media to pickup air. I was wondering why the media wasn't consistantly being picked up.
But my other question was, why are there 2 big crimps on this steel tube?
Steve L
73 coupe since new
Ottawa, Canada
i think it is a cheap and quick way of centering the inter tube in the outer tube. i have not looked at mine lately so i could be wrong on this
