If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Can somebody give me the password for disconnecting the main dash wiring harness from the connector on the steering column? It's the white plastic connector not the thin black one. It simply will not let go. Are there tabs on the connector that I'm not seeing or do I simply need to be a bit more aggressive?
Yes Tom, there is a tab on the bottom (standard column) or on the top (tilt & Tele) that you need to depress to pull the connector out. As you probably found out it cannot be removed until the black one is first removed.
