If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
1960 Corvette: Not using a group of friends to lift bodyoff. Besides grabbing the rockers with straps with clamps for fear of paint issues. Where on body, away from exterior paint, have some of you attached your straps/chains to pull body off level or close to level? This stripped body weighs about 350lbs. I will be using an overhead hoist for a center pick only.
DG
I have seen it done by lifting where the convertible top fastens behind the doors and where the female latches are for the hood.
Make sure the door openings are braced so it doesn' fold in the middle.
