The harness for the turn signal wire comes out of the fuse box and the end connector clips to the steering column. Do these wires go over or under the clutch push rod? A photo would be helpful
The shop manual shows the ground for the license plate light attaching to the light assembly. Does one of the mounting screws go through the light assembly, then through the ground terminal then into the clip nut?
I have looked at the shop manual and the assembly manual but it is not clear.
Mike
Mike
