years ago i got a NORS harrison radiator for our 62. as most are aware, the service replacement harrisons had a stamped aluminum upper inlet, whereas original inlets were cast aluminum. in the past, i've removed the incorrect stamped inlet and had a buddy weld a used original cast inlet on a service replacement harrison. i went to the barn today to get my bucket of original cast outlets and i see my three cast 62 style inlets have different alphanumerics cast into their body. all three are cast part numbered 3150896 as they shoud be BUT the alpha numerics are as follows: 11/65 for the first housing, D 12 9 for the second inlet housing and lastly, D5 5 . anybody know the meanings of the alpha numerics. i suppose the 11/65 could be nov of 65 and hence a service replacement harrison that was built when the cast inlets were still available to harrison. however, the D5 5 and the D 12 9 are confusing. your thoughts? thanks,mike
62 radiator question
