1957 C1 Power windows - NCRS Discussion Boards
  • Dan P.
    • December 1, 1990
    • 683
    I have seen some brackets to convert crank window regulators to Power .Any body ever done this .Any idea were to look for some power regutaltors. Was the power window and power top option one option or could they be ordered seperatly.
  • Roger W.
    • January 29, 2008
    • 572
    Re: 1957 C1 Power windows
    Corvette Central has a conversion kit. Pt. number 281097. ON an earlier post, this kit was discussed. One of the criticisms was that the switches did not look like originals.
    I just received a new catalog from Specialty power Windows. They have a new kit 5762-2CV for 57-62 Corvette. I don't know how close their switches are to original. Tech Line: 478-994-9248 1:30PM-4:30 PM EST www.specialtypowerwindows.
    • Roy B.
      • February 1, 1975
      • 7044
      55 to 57 nomad and Pontiac nomad are the same as Corvette// ordered seperatly
      • Ray G.
        • May 31, 1986
        • 1189
        Hello Roy;
        Do you know if the switches and the regulators are the same?
        Or just the switches, because it's the only other 2 door only switch?
        Thanks for your help. Always like your posts.
        Ray
        I hope you dance
        • Roy B.
          • February 1, 1975
          • 7044
          Originally posted by Ray Geiger (9992)
          Hello Roy;
          Ray
          There all the same parts
          • Dan P.
            • December 1, 1990
            • 683
            Thanks most all those regulators are the same . I used A 2dr sedan p/w regulator in A 55 Passenger car convertable .Mounted right one but the window did not go all the way up so I cut the arm and welded back at a differant angle so the window would go all the way up .On the 55-57 converables all the rear p/w regulators will inter change .I used 58 Cadillac's in the last one I built.Thanks
