If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
the loom was made of an isulating material (possibly asbestos based). It went on the fuel line back by the gas tank. Where the line is inside the frame rail positioned to line up with the muffler to keep the heat out. There was only one used.
Are there any supply houses offering this? I can't find any reference to it at Paragon or any of the other suppliers I have been using during the restore.
That certainly helps clear things up. I must be missing mine from the SS set I ordered.
I assume this armor protects the fuel line from making contact with the body and rubbing against it.
Is it just a wire loom inserted over the line?
