M-21 input shaft - NCRS Discussion Boards
M-21 input shaft
  • Joe R.
    • May 31, 2006
    • 1822
    M-21 input shaft
    I've read here that the metal Muncie input shaft is helpful to have handy when mating up the tranny to the engine. For a L-72 with M-21, which input shaft do I need? Where can I get it?
    Joe
  • Timothy B.
    • April 30, 1983
    • 5202
    Re: M-21 input shaft
    Joe,
    Any GM course splined input shaft will work fine. A used shaft lines the disc better than any of those plastic tools.
    • Tom P.
      • April 1, 1980
      • 1826
      Joe
      In the history of Chevy manual trannys, there have been only TWO types of input shafts: 10spline(coarse) and 26spline(fine).
      The coarse spline trannys were used up through 1970 and the fine spline trannys began in 71.
      You DO NOT need an input shaft from a Muncie to line up the clutch disc. ANY old junk tranny input shaft will work. For example if your Muncie is a 68 version, then a junk input shaft from a 55 Chevy 3sp will work just fine.
      • Joe R.
        • May 31, 2006
        • 1822
        Tim and Tom,
        Thanks for your help! Time to start searching eBay, junkyards and swap meets.
        Joe
        • Ray G.
          • May 31, 1986
          • 1189
          Joe
          Hello Joe;
          In a pinch, we have used the transmission itself. Without the bell housing.
          Support the trans. with a jack. Depends if your working in the Corvette or on an engine stand.
          Regards.
          Ray
          I hope you dance
          • Timothy B.
            • April 30, 1983
            • 5202
            Joe,
            If you trust your eyes, snug the pressure plate and center the disc by looking at the pilot hole and circumference around the pressure plate.
