C1 Frame alignment - NCRS Discussion Boards
C1 Frame alignment
  • Richard H.
    • March 1, 1985
    • 241
    C1 Frame alignment
    I would like to have my frame checked to make sure everything is in alignment. The body is on the car, but no motor. Should this be done with the body on or off the car? Also, can this be done with the current "modern equipment" or must it be done by "hand". Thanks. Richard
  • Stewart L.
    • March 1, 1980
    • 353
    Re: C1 Frame alignment
    You can do it by hand with the body on. I have C1 frame specs from Tru Way if you need them. You can make your initial checks with a tram gauge or some manual frame gauges. Modern computerized frame measuring systems would not have any measurements for a C1 in their data base.
    • Tom P.
      • April 1, 1980
      • 1814
      Some of the old front end alignment/frame shops which have been in business since the Civil War days will have BOTH the specs and equipment to make any measurements as well as frame adjustments on most cars. Although. I will admit that these kinds of shops are becoming scarce these days.
      In the Okla City area, there is only one place that I trust for these kinds of frame/suspension work.
      • Bruce B.
        • May 31, 1996
        • 2930
        Section 2 of the ST12 contains the frame specs. for C1 Corvettes.
          And if you add the diagram below to the one in the ST-12, you'll have a pretty complete dimensional package.
          • Richard H.
            • March 1, 1985
            • 241
            Thanks to all for your replies.
