Need a little help settling a disagreement about the correct fan shroud for a 67 BB. The assembly manual shows the BB fan shroud as having a cut out which looks to be about 4-5 inches square in the upper left corner. I am told that the AIM is NOT correct and there should NOT be a hole in the BB shroud. If the AIM is correct, would the the shroud that looks like it would work on a 67 BB be correct for? Thanks for your help getting this settled.
67 BB Fan Shroud
- Top
- Top
Re: 67 BB Fan Shroud
Steve,
I think what you might have seen (a 67 with no cut out) is an OLD OLD OLD NOS shroud. I have had several that did not have the cut out. Also one or 2 of those had the large angled cut on the bottom of the passenger side.
Rich- Top
SORRY TYPO early 66s DID NOT have the square cut out for the alternator. It seem most people dont read all the post, because they ask questions about things that are addressed, such as the alternator hole. Phil 8063- Top
