brake drums part #3830165 cast #3828671 fit C1 or C2? - NCRS Discussion Boards
  • Ian G.
    • September 3, 2007
    • 1134
    Hi Guys,
    Can someone tell me if brake drums part #3830165 cast #3828671 with W-10 on them will fit a fit a C1?
    Is it possible they would fit a C2 front or rear?
    thanks as always!
  • Pat H.
    • December 1, 1996
    • 421
    Re: brake drums part #3830165 cast #3828671 fit C1 or C2?
    Ian,
    I checked the drums I removed from my 59. Both have the part # 3782623 cast on the drum, one has a W-9 and the other has W-10. They worked fine. There probably a service replacement drums. I had them machined and they measure 11" inside. Hope this helps
    • Ian G.
      • September 3, 2007
      • 1134
      My understanding is that casting #3752623 (part #3752622) are original, but these look the same, except are for 3" brake shoes I have since found out
