If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Can some PLEASE send me some images of the wiring and vacuum hoses all lay out. I think I have most of it right but have some questions.
Any help greatly appreciated
Joe
68 L68 convert
Awesome! Could you also take some of the passengers side. A couple of things you can look at if you dont mind. What goes through the upper and lower radiator hole. Second, across the firewall, the route of wires and vacuum houses.
Thanks very much, you time is appreciatted
Joe
John thank you so much. Really help alot. Are you goin to Kissimee Fla? I have already signed up to get judged. Hope to have it all done.
Thanks again
Joe
