A/c Duct Work 72 Coupe Question
  • Edward J.
    • September 16, 2008
    • 6939
    My foam seals around the a/c and heat duct work are gone, my question is I was thinking of going to home depot and buying some of the PSA weather striping thats made of foam maybe about 1/2 wide and trying to see if this will work,has anyone tryed this before? I know that there a few venders that sell replacements, it just seems alittle steep its about 45-50 dollars for the kit, im not planing on removing any interior or exterior boxes, im just trying to increase the air flow through the ducts.
    • 11535
    Re: A/c Duct Work 72 Coupe Question
    Ed,
    I did this with Dad's 72. Your idea works well.
    Patrick
    • Edward J.
      • 6939
      Pat, thanks I'll give it a try.
      • Tom L.
        • October 18, 2006
        • 1434
        Ed, If you take any pictures I will find it interesting. I am having some air flow problems of my own. I put up a post this past week and got some ideas and any help from others is always appreciated. Good luck!!
        • Edward J.
          • 6939
          Lynn, I'll take few pic.s and post them for you.
          • Jack H.
            • April 1, 1990
            • 9906
            I originally used the pre-cut, foam seal set from the catalog house and found it'd been sitting for SO LONG in stock that PSA (pressure sensitive adhesive) was virtually useless. So, like Pat, I went to the hardware store and bought a role of off-the-shelf foam and used it. No problemas!
