Timing is set to zero degrees at idle. At 2500 rpms it moves to 40 degrees. The engine runs hot(water temp is 180 at top of radiator and 140 at bottom). and oil pressure drops to 15 pounds at idle (30 pounds at 2500 rpms.
How do we change the curve on the distributor?changed the fly weight springs. will test tomorrow but I'm looking for other possible causes. Any ideas?
Al
Al
