1965 Ignition Switch Question
  • Mark P.
    • May 14, 2008
    • 934
    My ignition key can be removed in the ON position.
    Is this likely caused by wear in the ignition switch ? I have heard the repro's work also work this way. Is it more likely I have a repro or service replacement ?
    If I buy a NOS 1116660 switch would this likely reemedy the problem and pass Operations ?
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: 1965 Ignition Switch Question
    Originally posted by Mark Pellowski (49021)
    My ignition switch (key ?) can be removed in the ON position.
    Mark -- you can remove the switch by pushing a small dia. pin in the hole while turning to the left. Then, undo the bezel and ease the switch out the back. Be careful as there's a lamp in a socket on the back.
    Here's a pic of an NOS 1111660 ign. switch (see the "660" cast on the side) and the removed tumbler beside it; if repro you can proceed from there.
    • Peter L.
      • June 1, 1983
      • 1930
      Mark - If the (key?) can be removed from the 65 p/n 1116660 ignition switch in the ON position, the problem is usually either with the key (a worn/well used key)or the ignition lock cylinder (tumblers) not the ignition switch. Pete
