Re: 1964 upper steering column play
Wayne, thanks for all of the info and photos. I will compare mine to your measurements etc. and get back with you. Yes, I replaced the plastic cancelling cam. Everything was replaced except the actual steering shaft and the steering column tube that the shaft goes through. I do have the spacer etc installed with the lower bearing. Wow! Yours was really worn. I have always read that the lower bearing didn't last all that long back in the day. I appreciate your help big time! Thanks, Tim
