Hi Gang,
Could use some help with a problem I have trying to order correct Water Pump Belt for my 65 396 without power steering. My old one started to crack and I ordered a new one from LICS which shows 2 different types available, ordered one with no p/s or p/s ? which I did not understand to begin with. My mechanic went and put it on, it's alittle too big and starts to chirp slightly. Call LICS this morning to be told no matter what you order it's the same size belt. Other after Market companys show two belts, others show only one and to top it off I can not find my old one to measure. Can someone please help me with either the correct size or does anyone have the GM part # - I looked in my j/m and no numbers are listed. Would like to send the bird chirp south for the winter. Appreciate any help you can provide. Thanks.
