Winter Storage
  • Michael V.
    • April 17, 2009
    • 9
    Winter Storage
    I Live In The North East....at What Temperature Should My Garage Maintain To Avoid Damage To My Corvette???
  • Michael W.
    • April 1, 1997
    • 4290
    Re: Winter Storage
    Keeping a low and stable humidity level is far more important than temperature. Condensation is the enemy. If you plan on working in the garage, choose a comfortable temperature for yourself, otherwise save some money and keep the garage cool. Cold air carries less humidity than warm
    Avoid opening the garage door and shuffling snow and salt laden vehicles in and out.
    Don't start the engine unless you plan on going for a good long ride that will warm everything to normal operating temp.
    • Tom L.
      • October 18, 2006
      • 1434
      Re: Winter Storage
      ...and if you keep the garage cool keep a dehumidifier running. When the car and concrete are cold and there is a warmer and more humid than normal day there will be condensation everywhere. Even the tools in your tool box will rust, trust me!
        • 15498
        Re: Winter Storage
        The colder the air the less moisture it will hold in vapor form. So for a given concentration of water vapor, the lower the temerature gets, the closer it gets to the dew point.
        The problem with winter storage in some places is condensation of water vapor in the air. This is most common when a spring cold front follows a spring warm front, and the temperature in the garage drops to below the dew point.
        • Edward S.
          • December 1, 1986
          • 514
          Re: Winter Storage
          I did away with everything and bought a bubble, one of the best investments I have ever made. I recently bought a new C6 and ordered another bubble at Carlisle. If I were you I would look into it.
          • Michael W.
            • April 1, 1997
            • 4290
            Re: Winter Storage
            How do these control humidity levels in the air?
            • Edward S.
              • December 1, 1986
              • 514
              Re: Winter Storage
              In reading the info and listening at Carlisle constant moving air does not allow condensation to form. At least that's what I was told, seems to work and at the same time you can throw a heavy tool at it and it just bounces off.
              • Floyd B.
                • November 1, 2002
                • 1046
                Re: Winter Storage
                Ummmm... You mean you don't keep your Corvettes in the living room?
                "Drive it like you stole it"
                • Michael W.
                  • April 1, 1997
                  • 4290
                  Re: Winter Storage
                  Probably because he's too dangerous with throwing tools around.
                  • David L.
                    • December 1, 1981
                    • 116
                    Re: Winter Storage
                    I live in far northern Maine and store my '58 in my unheated garage with a concrete floor. I place a sheet of clear poly on the concrete and drive the vette onto it. I cover the car and leave it until the snow goes and it warms into the 40's and 50's during the day. Also change the oil and remove the battery and store it in the cellar. I've done this for 28 winters .. not problems so far.
                    David
                    David
                    • Peter G.
                      • December 1, 1980
                      • 406
                      Re: Winter Storage
                      Moisture and Critters are the most dangerous. Both can be managed and maintained.
                      Peter Gregory # 4157
                      National Corvette Restorers Society Since 1980
