I just got my restored 3247 carb back and have a couple of questions. What is the proper finish for the following two items:
1) Divider block that the fuel line from the pump goes to before spliting to the two lines to the carb.
I have had two reproductions, one brass and one more of a silver
finish.
2) Carb Inlet Fittings
Again, I have seen two different finishes, one blueish black and
one closer to the color of the carb
The car is a 1966
One other non fuel related question. Is the ground strap attached at the back of the intake (under the ignition shielding bracket) supposed to have any paint on it. Mine is painted but I think it was sprayed when the previous owner was painting the valve covers. Not sure though.
finish.
The car is a 1966
