If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
Removing channel from my 60 Windshield Header molding
I searched the archives. I did this 15 years ago on my 57, and it was a B???! then. Any tricks. I remember trying to pry the lip over the edge of channel and then work to the end worked. Any tricks appreciated.
DG
