Flight judging question - NCRS Discussion Boards
  • Jim F.
    • April 7, 2008
    • 60
    Hey Guys,
    I have worked hard, spent a lot of money and waited a year to have my 70 Vette flight judged again. It's now only a couple weeks away! I have a couple questions and am seeking your expertise.
    #1--I have two sets of trim tings for my wheels. One set is original to car, with the clips positioned at valve stem hole. They have moderate road rash. Last year I lost 4 points for condition. The other set are definitely GM, from the 70's, but clips are about three inches to the side of valve stem hole. These are perfect, not a scratch. Which ones should I put on car for judging?
    #2--I have two air filters. Both are AC Delco with the proper text on the bottom. One has screen cut on bias, other has screen in horizontal/vertical squares. Which one should I use for judging?
    Thanks very much for sharing your time and expertise,
    Jim Fox
    • 15631
    Re: Flight judging question
    My opinion:
    #1 use the originals
    #2 my opinion would be neither style air filter is TFP for your car, but otherw will disagree. Bring both and ask the Mechanical judges which they want to see --put that one on the car.
    • Jim F.
      • April 7, 2008
      • 60
      Thank you! What does TFP mean?
      • Reba W.
        • 938
        Typical Factory Production (or Practice)
        • Jim F.
          • April 7, 2008
          • 60
          I cannot get an understanding of what the correct air filter is for my car even after reading judging manual. Help!
          • Harmon C.
            • August 31, 1994
            • 3228
            Your trim rings could be a toss up and your air filter won't be a big hit. Check and recheck operations at 25 points a line it can hurt you real fast.
            Lyle
            • James W.
              • December 1, 1986
              • 278
              Good advice. You can be trying to save nickles and lose dollars (so to speak). Operations losses are huge
              Jim
