The TIM&JG for 1970-72 says (pg.28) that the letter stamped on the key should be right side up with the point of the key facing the person and the notches to the right.
I have a set, with knockouts, and the correct alpha-numeric code.... with the letter being right side up when the point of the key is facing the left and the notches are facing the person.
Could someone please tell me what configuration is correct for a 1971.
But, your observation is important in that the grooves on the key shaft must be long enough to allow the key to be fully inserted in the lock for the key to operate the lock. Every once in awhile, I'll come across a key that is defective in that the grooves do not extent far enough and the key won't work in the locks.
Pete
