![Confused](https://www.forums.ncrs.org/core/images/smilies/confused.png)
A/C blower problem 66
Hi All The A/C in my 66 works fine. However when the blower switch is in the off position and the A/C switch is turned on the blower is supposed to start running in low w/o turning on the blower. Then it can be set on low,Med. or High. When the A/C switch is turned on the blower starts running in high blower speed. I have changed the blower switch,theRelay switch, the resistor, and the switch on top of the heater housing. I also removed temporarily the condenser at the blower motor. None of these things have helped. Any ideas would be much appreciated. Regards Jim Lucia
Tags: None- Top
Re: A/C blower problem 66
Jim,
along the lines of what Albert is saying. Also check the wires that go into the resistor and switch to make sure they have the correct orientation.
I have put many new harnesess in the had terminal positions wrong and also had original harnesess the someone prior had switched.
Rich- Top
I can't comment on a '66 Corvette, but I was 'blind sided' when I read the theory of operation section from the Chassis Service Manual for my '71... I couldn't BELIEVE the number of differences in the Chevy lineup (model to model) regarding how the blower motor was intended to turn ON/OFF relative to the center console/dash switch setting!- Top
