Battery Tender @ Carlisle - NCRS Discussion Boards
  • Gary B.
    • September 30, 1987
    • 305
    Is there a vendor at Carlisle that will have "Battery Tenders" for a reasonable price? I need 2 or 3.
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Battery Tender @ Carlisle
    walmart sells a schumacher battery maintainer that sell for $20. schumacher is the guy that runs all those drag cars including top fuel. i have a couple and they work great
    • Dick W.
      • 10483
      Tom Kobbman of Restoration Batteries will be there. Spaces C 84 and C 85
      Dick Whittington
      • Patrick T.
        • September 30, 1999
        • 1286
        Tom Kobman of Restoration Batteries will be there. Spaces C 84 and C 85
        I have "Battery Minder Plus" for my cars and I got them from Restoration Battery. They are hooked up to the car batteries 24/7. Not cheap but the best. PT
        • Steven S.
          • August 29, 2007
          • 571
          The Captin Lee's venders also sell battery tenders. They usually have a few spots throughout the show.
          • Brian M.
            • February 1, 1997
            • 1842
            There's a guy right in front of the food court that sells them.
            • Louis T.
              • July 31, 2003
              • 282
              Hi Gary,
              Carlisle or from a number of the large Corvette parts houses (the latter can be cheaper as they sometimes offer a discount and free shipping at Carlisle). If you want a float charger that also desulphates (removes battery life shortening sulphate crystals from battery plates by using high frequency pulses), then you need something like the BatteryMINDer sold by a number of vendors including Restoration Battery for $45 and up.
              Louis
              • Jeffrey B.
                • January 1, 2006
                • 82
                I just bought a new in package Battery Tender Plus on E-bay. The total price including shipping was $44.80. They cost about $65.00 plus shipping from some of the Corvette vendors who sell by catalogue.
                Good Luck
                • Stephen R.
                  • May 20, 2008
                  • 302
                  I bought two battery tenders from Harbor Freight, $7.95 each. Put one on the Vette and one on my motorcycle. Been using them for over a year no problems.
                  • William T.
                    Infrequent User
                    • April 1, 1985
                    • 12
                    Try Amazon.com. They have excellent prices and free shipping. The Battery Tender Plus models are in the low $40 range. Best of luck!
                    • Gary B.
                      • 305
                      I have seen these. Do they shut off when charged? Or do they just keep up a trickle charge?
                      • Harry S.
                        • July 31, 2002
                        • 5345
                        Gary, the best way for me to explain is to say that the Battery Tender Plus has some intelligence built in. When connected it tests the battery for a charge. If the charge is not where it should be it starts charging. As it is charging it keeps testing the battery. When it detects that the battery is charged it goes into standby mode and stops charging. Then on a regular basis it tests the battery and if it detects the battery is low it starts the process over again. This may not be exactly how it works but this is how I interpret what happens.
                        I've had one on my C6 for several years when parked and have not had a problem. I keep another one to change between two other batteries I remove for the winter.
                        • Clem Z.
                          • January 1, 2006
                          • 9427
                          the schumacher one works the same way and you can see the indicator light change even when you open the door on the car
                          • Michael L.
                            • July 31, 2005
                            • 562
                            I'm with Clem, I have two Schumachers for $19.95 each, bought them locally, and they do shut off when charge is complete.
                            Mike
                            • Gary B.
                              • 305
                              Mike
                              Thanks for all the replies. I can not seem to locate a store that sells the Schumachers .
