If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
I'm looking for a copy of a prior restorer article on excessive fuel pump pressure. My carbs leak out the throat. Pump has 6 lbs of pressure. I remember reading an article on drilling the pump housing but can not put my hands on it. Thanks
Greg
Use the Corvair turbo Carb kit and lower the floats a hair
