68 427 Clutch Housing Cover Bolts
  • Rick L.
    Infrequent User
    • September 21, 2007
    • 22
    Anybody know what size and length these bolts are suppose to be? Mine are all missing.
    Rick L.
    • 43133
    Re: 68 427 Clutch Housing Cover Bolts
    Rick L.
    Rick-----
    These are special bolts of 3/8-16 X about 1". You must use these special bolts for this application. They are available from GM but I'm 3,000 miles from home right now and I can't recall the part number. However, I recommend you buy ARP bolts for this application. You get them in a 6 bolt kitt and they are the best.
    • William C.
      • June 1, 1975
      • 6037
      Exactly what bolts are you looking for? there are three possibilities, the bolts that attach the clutch to the flywheel, which are the ones Joe has discussed, also there are the bolts to attach the bellhousing to the back of the engine, and also the bolts used to attach the metal cover to close out the opening in the lower half of the bellhousing. Which ones are we talking about?
      Bill Clupper #618
        If it's the sheet metal lower inspection cover, I think those are indented hex-head 1/4"-20 x 3/8" with a captured star washer.
